Was always alittle off on the wheelbase after installing the 9". I didn't use the original driveshaft and for some reason the replacement was alittle short. Either I measured wrong or the shop misread my length numbers?? My wheelbase had been short roughly an 1.250" ever since. Anyway, have string lines strung and looking at near or right at 108.5" wheelbase with 3 degrees of pinion angle. Specs are 108.1" Looking for someone that has stock upper and lower arms with stock wheels and tires or something with 26" tall tires to give me an average gap measurement side to side between the tire and the front of the wheel opening. Parallel to the rocker and just touching the tire. It will most likely be different from side to side, just looking for an average. Just trying to make it look like it should.
Thanks!!
Steve
Thanks!!
Steve
