Looped my steering lines
1980PontiacWagon
686
Northern Virginia
There probably isn't enough fluid in the box for it to function properly, so that "catch" you feel is probably when the box binds for a second because it is trying to transfer fluid around.
Tip
60
How can I get more in it? When I remove a line fluid comes out, so I put some in the opposite line and sealed it. Any more options?
grizwald
3,300
Ontario, Canada
i had the same set up as you (looped lines on a p/s box). i came across a deal on a manual steering box from an s10 and put it in the car. only regret i had was not doing it sooner cause it was so simple.
Tip
60
You didn't have any problems with tha loop did you ?
racecar77
2,438
Crete,IL
A looped P/S box is half-a$$ed. It's not the same as a manual box. If you can find a manual box I would change it. They're only $50-$75 for a good used S-10 box.
The fluid in a power steering unit assits the recirculating ball setup that actually turns the steering gear. When the fluid isn't being pumped under pressure things get tight & "notchy".
Tip
60
Ouch Racecar77! Jk, I was just going off some other "horsepower adding tips",but I'll look for tha s-10 box. But I found out my idler arm is bad. Thanks guys for your input!
racecar77
2,438
Crete,IL
Sorry, I should have rephrased my wording. I didn't mean to say you were half-a$$ed, just the procedure of looping the lines. It is a common practice to do it that way, but it isn't correct. You're going to have guys tell you, "I did it and had no problems." It still isn't right. The manual box swap is cheap and very easy to do, takes about an hour at the most. Tommy explained it pretty well in his post. The power box is designed to work with fluid pressure, when you loop the lines it will still steer but not properly. Good luck. P.S. I have a perfect, slightly used idler arm, where are you located? You can have it if you want to pay the shipping. Lee
