But now the brakes feel spongy. Well they allways have but I thought they would be more stiff.I have bled them at least 2 times there is no air in them . Any ideas?
What was the stock bore vs the bore of your new master? If you went up or stayed the same (mc bore size) that may be why the pedal feels spongy. You might try going with a smaller bore mc to give you a firmer pedal.
My brakes are spongy - upon inspection, I found that both front brake hoses are BAD and about to break at the upper end!! :shock: Bad hoses can swell when the brakes are applied, and in this case, one is also leaking. I would check your brake hoses and go from there.
Im going to go with ss braided line to get rid of the rubber soon. I did get them working a lot better doing some of the things that were suggested above,Longer rod helped a lot . Allso bleed bleed bleed I thought there was no way air could be in the system after bleeding twice . I was wrong ,after the third time it was 10x better.
