Manual brake weight savings
ALaRock
128
jackson, mi
I am thinking about making the conversion to manual brakes and I was wondering what are the benefits as well has anyone calculated the weight savings from stock to manual conversion?
malicad
1,383
South Milwaukee, WI
Im actually just about to do the opposite. Can't stand manual brakes anymore on the street. Track only car, sure. Street, heck no. A Toyota Camry can out stop me. Not good.
~JM~
99
I wouldn't think that there would be much weight savings. What does a vacuum booster weigh?
Now if you have a GN or T-Type removing the original Power Master brakes will save you some weight.
malibudave1978
226
Houston, TX
9.0lb Vacuum Booster
3.3lb Cast Iron Master Cylinder
12.3lb Total
0.26lb Manual Brake Adapter Plate with Pushrod Retention Cup
0.05lb Firewall Gasket for Adapter Plate
0.42lb Stainless Steel Mounting Hardware
0.33lb G-body Adjustable Pushrod
2.30lb Aluminum Dodge Master Cylinder
0.05lb Brake Line Adapters
3.41lb Total of Manual Brake Kit
8.89lb Weight Savings
Ed Cannon
1,682
Johnson City Tn
If its a drag only car then its a no brainer. If you drive on the street I would keep my power brakes.
ALaRock
128
jackson, mi
Yeah its a street and strip car. I was looking to clean up the engine bay and remove some unnecessary weight and I thought it may be better, but thanks for the pros and cons. I think I will wait or go a different route.
