Mini Starter
richamer1
524
New Carlisle, Oh
Anyone know the year and model for a GM mini starter straight bolt pattern 153 tooth flywheel. Also does anyone have the part number for the starter to block brace ? Motor is 1973 454
melloelky
3,654
mass
those GM mini's are staggered pattern.as are the 454's i've come across.
4,770
39
I have a 153-tooth mini starter that I bought on eBay many years ago, so there was no application given. I just looked for a starter for a 153-tooth flywheel.
You need to use special hybrid bolts, that were used on the LT1 (PN 12338064 and 14037733). These bolts have an additional step in the knurled area to properly index the starter nose with the block. I took these pictures so I would not have to research the fitment, again. For a 168-tooth flywheel mini starter, you would need 2 of the long bolts.
