My LS1 swap
71Malibu402
1,614
Knob Noster, Missouri
Nice....I need another G body to do this to.
455_82malibu
1,400
WISCONSIN
Stock pan fits fine, Ill know more when the mounts are in this afternoon, but I have 5" of ground clearance. Im running the stock heads, which flow the same as the Z06 vette heads, just larger chambers. Im using the Edelbrock 2216 cam , edelbrock 800 carb, ls6 springs. If you buy a truck 6.0 with the HD 4l80 trans it already has the spacer and correct flywheel.
malibuguy
3,775
Finksburg, Md
all these LSX swaps really make want to do one...i would have to do a 4.8 tho ;)
how do you control the ignition?
ILLEGAL REGAL
7,160
Tinley Park,IL
blah_sign.gif lame_sign.gif 6.0 or go home
MSD makes a box to control the ignition with a carbetuter
malibuguy
3,775
Finksburg, Md
:lol: well, this is far away if i actully do, do a lsx swap
prolly end up with w/e i can afford, i would like a 6.0, but we'll see
& sweet, MSD rules
If you can't afford a 6.0 you can put a 4" stroker crank into a 4.8 or 5.3 block and bore it to 3.900 and make a 383. Or just use a stock 5.3 crank (4.8 is smaller) and you'll have a cast iron 5.7.
455_82malibu
1,400
WISCONSIN
Took it for a ride, the timing pills are tricky, but after playing around I found what the motor likes, it pulls awesome, If I dont shift at 7000 it would climb even higher, thats even with 3.42 gears, which should be perfect on the bottle in the 1/4. I dont know why anyone wiould build an old school V8
