need help!!!
malibuj
1,074
Lancaster PA
My brother has an 84 short bed s 10. he runs a n/a 383 w/ t350. Problem is we keep breaking transmissions at the bell housing. first trans was at the track at 1000 ft mark spun trans sideways in truck. second was on the street. We run solid eng mounts and polly trans. Is this a bad thing? should we have all same mounts? Im starting to think its the cage. We have an 8 point all inside the cab, w/ no bars going out into the bed. making frame flex? Any other ideas? thanks for your help. joey...
DFWMalibu
999
Dallas,Tx
the mount combo should be fine..... as long as you don't have solids on the motor and trany that should alleviate that as the cause.... maybe the driveshaft is too short and when the truck squats it jams the shaft into the transmission...
Chris K.
malibuj
1,074
Lancaster PA
when we mesured for drive shaft. we put all the way in, then backed it out 3/4" and took measurments from their. Is this the way to do that? thanks joey...
DFWMalibu
999
Dallas,Tx
well I know on my 86 shortbed it moves drastically but it was also lowered quite abit....
Chris K.
