need pics of ssm bars installed!
clint
2,503
brodheadsville,pa
i bought a set from a member here not to long ago but would like to see how the plates are bolted to rear end on the lower control arm...thanks clint
red barn
628
Syracuse, NY
James Bond
1,359
Earth
is there something welded to your control arm in that second pic?
red barn
628
Syracuse, NY
Yup. Piece of roll bar tubing welded through the arm. Not proud of it, but it did work for consistent 1.51-1.52 60' and 10.50 passes. I have made some changes this winter and that set-up is no longer in the car. I found another set of SSM bars and am using a D-M products anti-roll (although I bought a new piece of 1-1/4 x .25 tubing because I didn't care for how the D-M kit put the mounts real close to the center section width wise)
However that set-up remains all set-up in the shop in case I struggle with the new set-up. Was it the correct way to do it....probably not. Did i leave some 60' on the table...probably, I will found out soon enough. did it work consistant enough to help me qualify for NHRA division 1 bracket finals......you bet
