new engine with mysterious tick
Z-man
1,058
Barnesville MN/ Fargo ND
Last weekend i dropped in my new GMPP 290 hp engine. got everything together and it had a tick that starts around 1500 rpm ](*,) but is not there at idle. I tightened down the headers and that helped some, but the tick is more pronounced at the front of the engine. Pulled the V/C the tired to push the lifters down and they were firm but they do slide a bit on the valve stem (side to side) I broke the engine in on VR1 and prelubed it. It makes 65 psi oil press cold and 50 hot. did I wipe out a lobe on the cam? Do I need to tighten the rockers a bit? I need to get this resolved before I do (more)damage to it. :-k
cleetus
180
NJ
You know how to hot lash the rockers? Give that a shot.
If it isn't the rockers, I'd bet you have an exhaust leak.
bukweet
2,803
Mississippi Gulf Coast
Put one end of a broomstick on the fuel pump and the other end to your ear. :-k
50/50 shot that you find your "tick".
I had a similar problem years ago.
The spring on the arm of the pump had either moved or was broken(don't remember which) and gave the exact same symptoms you have.
bukweet
