ok ls1 swap again
ILLEGAL REGAL
7,160
Tinley Park,IL
Hmmm I'll have to remember that later on.. but I guess it depends on where you place the motor on the crossmember. I think I'll go with a stock manifold to get it goin.
Tell me about the pedal and hydraulic setup. And nobody makes a cable clutch setup for the 6gear??
JRodS79
1,567
kansas city mo
you will want to keep it hydraulic faster pedal responce and you can use the stock malibu pedal set up and stock clutch master for the ls1 car from what i understand
NOT_SLOW
1,565
WI
http://www.montecarloss.com/ls1montecarloss/
look here
JRodS79
1,567
kansas city mo
i dont know a bunch so dont quote.
the last clutch we did at the shop had a self adj pressure plate
another would be a floating slave cyl through out bearing combo
i dont know if there used in conjunction
best for performance minded it reg clutch with an aftermarket floating slave bearing combo. they use them on the roundy round stuff and its pretty cool how they work
JRodS79
1,567
kansas city mo
lt4malibu said:
pedal/hydraulics are cake for a 6speed, get a pedal from John Bzdel and mount the master on the firewall using 388bu's template.
i found this in a post on LS1tech, supposedly these schoenfeld headers fit g-body's > http://www.schoenfeldheaders.com/LS1-STREET.htm
here's the thread on ls1tech > http://ls1tech.com/forums/showthread.php?t=641108
wow. thats one more thing that makes me really want to convert to ls1
ILLEGAL REGAL
7,160
Tinley Park,IL
I never seen the price on the pedal, but I seen he was selling the modified pans($259).. do ya know if he still is?
lt4malibu
2,384
NJ
if you want the ability to adjust it you can get an adjustable master for an f-body. i had a stock master in my car with the 6speed and it worked perfect.
ILLEGAL REGAL
7,160
Tinley Park,IL
After looking more at that site I think an auto is easier and would better suit my goal.
Any idea what shifter to use with the o/d or can the column shift be adapted somehow and just not have 1st gear capability?
lt4malibu
2,384
NJ
monte carlos had 4speed automatics....
6speed is way more fun though. best thing i ever did to my car!
