OK new here
eldabo
1,811
Mobile,Alabama
What E f I should I run if I'm going procharger ? I;m looking for a system . Im new at this ?????????????????? I have nothing now. but a carb.
Thanks.
David
Deuce4935
341
Chicago, Il
Here's a small block suggestion. Get a 95'-97' LT1 intake, have the intake modified(lt1intake.com) so that you can use a regular HEI distributor. Order a FAST computer and harness because it allows better tuning of the system. That should make for an excellent combo. Good luck with it.
Also, Vortech makes a blow-thru setup for carb'd applications, you could save some $ there.
injected
432
Quebec , Canada
I am doing a complete custom set-up ! It is alot cheaper and you ca do what you want !!
Megasquirt Stand alone system , it is very cheap and guys are going fast with it !
eldabo
1,811
Mobile,Alabama
Ill check that out ,does it it have boost capability?
eldabo
1,811
Mobile,Alabama
Man I have to say that im no were near that handy.thanks for the info
injected
432
Quebec , Canada
yes it has a 3 bar map that you can use as a boost reference !! It's a wonderful system !! I am soooo proud now i can finaly help somebody with something i realy know ! I am a liscence electronic specialist . I was dying here waiting something like that to happen so i could finaly show everybody what i was capable of !!!!!! cool.gif
eldabo
1,811
Mobile,Alabama
How much is home built vs over the counter stuff ?
injected
432
Quebec , Canada
Around 350$ complete for a DIY and aroud 3500$ for a renound company !!! 8) But wait dont tell those import guys !!! That is for the ECU, harness and hardware. Not counting other stuff like injectors and fuel rails ect..ect..
Go there you'l be very impressed ,thats were i buy my stuff !!
DIYAutotune.com let me know what you think
eldabo
1,811
Mobile,Alabama
Sorry I didn't ask the right questinon .When you say diy does that mean building you own pcm ? I mean soldering up your own board and in depth stuff like that, or do you piece it together with over the counter stuff thats made for other things?
injected
432
Quebec , Canada
I bought there solder yourself together kit !!! I am not that good buying over the counter stuff !!! Well it is almost imposible to do so .You'd have to fine somebody that could build you a circuit bord with no flaws...It would cost you probably the price of your car !!!! :shock: And probably even more !! The company that make Megasquirt ecu ,probably spent millions of dollars to comme up with there first board that worked good !
