You have that correct as far as the geometry requirements go. Four links that aren't all parallel in plan view are all you need, so it's still best to avoid having the uppers end up fighting with a Panhard Bar or Watts link especially when you're driving at race levels. However, a street car that still has all the rubber bushings in the rear suspension and driven moderately hard may benefit more from better lateral location of the axle than it gives away by having too many links trying to do the same job.malibu43 said:Thanks NORM,but am still dont get something right,i´ve read that the panhard bar, can only work with parallel 4 links, not like ours malibu they have triangulated 4 links and its no necessary to have a panhard. am ok in this or its something also that i dont know about this car?.
I would have expected the right rear to spin on a hard right turn before it would on a hard left. Does it also do this? I would investigate the corner weights before trying a PHB. Something has to be way off in order to spin the outside rear tire, whether you have a working posi or not, and needs to be fixed first.i will tel you,that i race my bu as road course racing,i have lots of problems with the rear suspension,because the spring cannot be cut to get the desired height,so i swap them for a nissan springs, they are light then oem,and it can be cut,but they are still to soft,my car weight total its 2.797 lbs, very light,my mayor problem its when i make fast left hand turn the rear right wheel its spinning i asume thats why i dont have posi unit,thats why i want to run a panhard bar.do you have pics and how to install in it.
my bests regards from the last country of the world CHILE.
