parachute mounting pictures
Lonster
61
Bedford Pa.
I need some Ideas in mounting my parachute and still be able to see my tag.
thanks Lonster
ILLEGAL REGAL
7,160
Tinley Park,IL
the shop that did mine didnt understand what I wanted and made the mount removable and the tether part non-removable and after it was done had to change it so the tether part was also removable. So if I did it over the mount would be on the tether part outside the car and the whole thing would remove as 1 piece.
10secBu
4,284
Westminster, MD
One half inch bolt under the car behind the bumper and the whole outside chute mount can slide out/off.
I also welded a sleeve inside the chute mount so it wouldn't crush or oval the tubing as the bolt was tightened down.
Lonster
61
Bedford Pa.
TTT
rock
2,475
Chicagoland area
thanks Lonster
I think your question has not been answered (yet). You want to mount the parachute and still be able to see the license plate? I think you would have to mount the parachute so it sits eye level over the license plate.
ILLEGAL REGAL
7,160
Tinley Park,IL
^^^^^it wont happen.. mount the chute under the tag and it's worthless and probably just fall and drag the ground. Mount it too high and it'd just look plain retarded
remove the setup since you dont need it on while street driving.
Lonster
61
Bedford Pa.
ttt
Killerdave8813
904
Cincinnati,Ohio
blownbigblock said:
Heres mine,just pull pin and remove the teather line and it's off
That's a cool looking license plate surround,what's the story on it?
Oct 21, 2011
5
I have a Shroud Pilot Chute,that I am going to install on my 85' Grand Prix G-Body car.Does anyone have pics of the underside,how the frame work was made,where they connected it to and with size thickness of metal? I need to see how ya all are doing them as I have seen a ton of g body's on a "show us your g body" race car" I have PM ones that look like what I want and still have no pics yet ](*,) .Thanks to you in advance for any pics or guidance on this part of my build.I know the car will need it,for the class it will be in and Speed it will reach in 1/4mile rules says what 150 ?mph.
Kind Regards,
Jason
