Hmmm, first post seems to be Fubar'd, so here we go again...
I've installed the Steel Concepts kit. At first, it was pumping fluid fine to all corners, but leaked at the Wilwood residual pressure valve cause I used the wrong adapters. Installed the right adapters, no leak, but now the pedal was rock hard. It would pump fluid fine to the front, but when I bled the rears it would barely push any fluid and had to press the pedal VERY hard to get them bled. After talking with a few people smarter than me, was told I didn't need the residual pressure valve because I was using the factory combo valve and that had one built in. So yesterday I removed the Wilwood valve by replacing the entire line from the Master to the combo valve, where before the Wilwood valve was located midway in that segment. Now, same problem, fronts bleed fine, rears are very difficult to bleed, and the pedal is rock hard with almost no braking power. So what's up, is the stock combo not compatible with the wilwood master cylinder (can't see how, it's just pressure and fluid, right? What can't be compatible), is my new master cylinder bad, or something else entirely different?
Help, I only have seldom occasions to work on the car, so it's been almost two months off the road cause my attempts at a fix have been futile so far.
