Pistons for a 30 over 350
dennisM
224
Bessemer, PA
The new guy here asking a question. I found a list of piston and ring kits at summit:
http://store.summitracing.com/egnsearch.asp?RC=100&N=700+4294925232+4294839001+4294852538+4294791253+4294908216+4294908395+4294840140+115&Ntt=&Ntk=&Ns=P_SRE_DisplayPrice%7C0&rsview=sku
Which one should I get? I see that different pistons will give me different compression. I don't know what to go for. Just want to run it on premium pump gas. Will be running Vortec heads.
Too bad a stroker kit is just out of my price range. :cry:
madmoose63
449
Bryan,Ohio
If you are just going to cruise it with occasional track time i would run the hyper pistons with 9 to 1 compression...imo
bottlesempty
246
southern maine
x2on hyper if runnig naturallyaspiratedIlike a little compression but the stock springs on a vortec head wont support any real llift so cam choices are very limited unless you pgrade the springs Irun93octane with 11.5compression with a pretty aggresive camthatwill bleed off some compression I've had no issues would go10: 1 for your comboconsidering your r cam choices atleas t 9.5 9.1 may be a little soggy down low
dennisM
224
Bessemer, PA
Haven't bought heads yet. Got cam last week (Comp's XE268H). This was before I decided to go 30 over. Wish I could get Dart heads, but they're just out of my budget reach.
holtjohn
516
your gonna want to shot for 9.0 to 9.5 with that cam. I have that cam in my street motor and I love it, I think you will be happy with that cam too. That cam is gonna push the limits of the stock valve spring vortec heads just to let you know.
dennisM
224
Bessemer, PA
Thanks for the replies. What do I look for in the product details for the compression? For instance this one: http://store.summitracing.com/partdetail.asp?part=TRW-8KH345NCP30&autoview=sku
Yea I know. Talked to a number of people and they said as long as I buy them new (which I am) it will be ok. Maybe later on I'll get those nice Iron Eagle Platinums someday ;)
ProJunk
902
Glendale, AZ
The Vortec head has a very efficient combustion chamber and is tolerant of higher compression ratios on pump gas. I'd shoot for a flat-top piston, preferably with only two valve reliefs to get as much compression with the flat-top as possible. Depending on your deck height & head gasket thickness, you should be able to achieve anywhere from 9.5-10:1 with this type of piston, which should be ideal. Retainer-to-valve-guide clearance can be an issue at max lift with Vortec heads, so check that carefully during mock-up. You'll want at least .060" clearance between the bottom of the retainer & top of the valve guide at max lift. This is much easier to check if you install a set of lightweight checking springs on one pair of valves. A set of stock LSx beehive valve springs & retainers is a cheap & easy drop-in upgrade for the Vortec heads that will give you more spring pressure, more coil bind clearance, and more retainer-to-guide clearance.
360demonRT
381
central Ky
link to the above mentioned beehive springs? or are they a stock deal. i hope one day to have enough money to put my pos together lol
ProJunk
902
Glendale, AZ
Stock LSx valve springs & retainers, especially the LS-2/LS-6 springs, are a good cheap upgrade for Vortec or just about any conventional SBC cylinder head. You could also use aftermarket LSx beehive springs such as the popular Comp Cams 26918-16 springs, but those don't really fit into the "budget" category for cheap upgrades. SI Valves has a good beehive for reasonable money that offers a bit more spring pressure & allows up to .610" lift under part # VS1118-16.
dennisM
224
Bessemer, PA
I'll definitely look into getting those springs.
I want to reuse the rods from my stock pistons. If I wanted to get the ones with the two valve reliefs, will I need to get the rods machined due to the floater pins?
