Pitman arm
bhrevans
86
Amarillo, Texas
I am going to change my steering gear from the 605 box to a box with a 4 bolt top plate. Is the pitman arm th same for both? Thanks for any help.
i think the only real difference is going to be bumpsteer. you culd use the s-10 pitman and buy the s-10 idler set up to equal the overall angle of the dangle ya know. if your pit/idler are at the same height in the system, then there shouldn't be any problem with bumpsteer, or an uneven steering centerlink.
