PPG Paint school.....waterbase
StreetBu
4,158
3
Upstate NY
t5montecarlo said:
GM used water-based paint in the '80s. The SPID on my 1986 MCSS says something like water dispersed paint.
Does everyone remember seeing all the late 80's early 90's vehicles driving around with large sections of paint missing and primer showing? GM actually "recalled" them and painted them for free it was such a large problem. That was water based paint IIRC. The formula has been improved quite a bit since then :)
melloelky
3,654
31
mass
Does everyone remember seeing all the late 80's early 90's vehicles driving around with large sections of paint missing and primer showing? GM actually "recalled" them and painted them for free it was such a large problem. That was water based paint IIRC. The formula has been improved quite a bit since then :)[/quote]
:-k i was told that had happened because the general hadn't put enough clear to provide enough uv protection and thats why the the sealer and base gave way.i think it's one of those things we'll never know the awnser to.
shaggydjlg
216
Hersey,Mich
my ppg reps and i just had that dicussion what actually happened is the factories tried to keep costs down because paint prices were on the rise so what they did is skip a few steps.First the grey that u see under the peeling paint was not primer nor was it sealer it was the E-coat factories sprayed right over it without sanding it or sealing it. if they would have sealed it the sealer wouldve stuck to it..The reps explained it this way to me...sand and seal it.When u paint and the paint drys it grows (fingers) and they dig in the sealer to hold it there the E-coat is hard and the paint will not penetrate it as good as the sealer does. Second they sprayed really thin paint over it.If you peeled it u can actually see through it ..Hence the uvs goes right through to the e-coat causing the paint to blister or peel. On my 90 dakota it was repainted so u cant tell but on the 94 i just bought all the silver is peeling and the green is not reason being there is more paint where it is green (they painted them all silver first then the 2nd tone over that)and the uvs are not going through the paint to make it peel so it has nothing to do with it being water base paint.It was a matter of prepping and being skimmpy on the paint.
melloelky
3,654
31
mass
that's messed up!you might be able to get away with that today with how far sealers have come in the past ten years!i'm told that i don't have to skuff the e-coat on the undersides but for me that mechnical adhesion(sanding) helps me sleep at night! [-o<
shaggydjlg
216
Hersey,Mich
Ive been gone for too long yes melloelky ive been told the same thing and i do sleep better at night also because i sand the E-coat before spraying.Ive sprayed a lot of cars with this water base and some turn out great and others.... mostly the light colors and black metallics seem to get the mottling effect going on.We tried a lot of differant things and so far on some colors we really hate it.We learned by turning the air pressure up and holding gun farther away (about 2 foot) on the control coat it seems to help a lot.We have also noticed that a lot of there paint chips dont match the color of car.Hows the colors and painting for u going??
shaggydjlg said:
My shop decided that we may not use the dryer and we will let it air dry it takes a bit longer but right now we dont see a need for it because we paint alot of panels at one time.And it is still dries faster then solvent.
How's that working for you so far? I'm no body man, I'm just curious becuase PPG says NOT to "air dry" H20 based. They recommend corner fans for down draft booths because they want turbulant air flowing all over the paint. Both shops I deal with had them installed when they started using H20 based paints.
shaggydjlg
216
Hersey,Mich
HMM ive never heard that comment from ppg infact they say u can air dry paint but dont recommend it just takes longer and u have a 24 hr window to clear.we havent had any problems with the paint drying we will use the hand held blowers a little bit but only on bumpers we didnt have to add anything new to paint booth as far as turbines or other special blowers.
melloelky
3,654
31
mass
shaggydjlg said:
Ive been gone for too long yes melloelky ive been told the same thing and i do sleep better at night also because i sand the E-coat before spraying.Ive sprayed a lot of cars with this water base and some turn out great and others.... mostly the light colors and black metallics seem to get the mottling effect going on.We tried a lot of diffent things and so far on some colors we really hate it.We learned by turning the air pressure up and holding gun farther away (about 2 foot) on the control coat it seems to help a lot.We have also noticed that a lot of there paint chips dont match the color of car.Hows the colors and painting for u going??
if nothing else,i've found that it's worth the time/effort to do as many spray out cards as needed and keep them on file for future use,it's a pain when their's ten variants but worth it if the chips from the jobber aren't working out for ya.tell the writer in the office to start including time for these let down cards to aid the color matching when they write the job.it works out in the end because you do them everytime you run into a color you havn't done yet but STILL write/get paid for it everytime.we've been using whats called a sun gun.its a light made by 3m that produces sun-like brightness if the sun isn't outside for comparsion.i also find that before trying to match i will compound an adjecent area even by hand to get a better look @it.that control coat in the end is where it's at,you sound like your far enough away with the increased pressure too.i could see the mottling with the mettalics but not with the solids.i know its a stupid ? because the h2o covers better/faster than the solvent but are you putting enough material on?could it be the sealer showing through?one thing i've had to change from mixxing the solvent was to use a rubber mixing paddle vs the old wooden stick so your sure to get all the metallics from the sides of the cup.are you using envirobase or what?
shaggydjlg
216
Hersey,Mich
yes we have a sun gun and yes we r using eviro base from ppg the solids u do not have to put a control coat over it .I am running 4-5 coats over all they only recommend 3 coats plus a control coat sometimes ill control coat it twice I only get the mottling on certian colors!! when we sprayed solvent base coat the silvers were terrible to match and blend. With the enviro base we do not have any problems at all no mottling or anything it looks perfect and it is sprayed exactly like I was taught.
We did a taurus x a light blue color we could not blend it for the world and the mottiling on it was rediculous we even had a tech guy come in and help and he couldnt figure it out.We finally messed with the air pressure and gun distance and got it to look good it took 3 days to paint it!!! The other color was a black w/ gold metallic flake a saturn color I sprayed it and cleared it.Looked perfect in the booth when i pulled it out in the main shop the hood was mottled bad I ended up letting that one go out because when u pulled it in the sun u couldnt see it.Some people wont pay attention to the color as long as there isnt a dent in it.But this light blue really kicked us hard.I was just wondering if u ever had the same problems or not
