Proportioning Valve Position
Rodman
17
SE Ohio
Does it matter where the prop. valve is located? Would like to move it up near the master cylinder (like earlier GMs) from the stock frame location. Disc/Drum setup.
Thanks
StreetBu
4,158
3
Upstate NY
That will work fine. Doesnt matter where it goes as long as it's hooked up correctly.
Many of the aftermarket brake upgrade kits have the combo valve mounted on a bracket just below the master cylinder. It's just fine that way.
