if i run 4 wheel disc brakes all the way around my malibu will the stock proportioning valve work or will i have to buy an aftermarket one?do i run the lines through that and take the stock one off the car? any help greatly appreciated thanks casey
x2.i picked up one from inline tube.bolts into the oe location.dr78442 said:You need to change the valve. I used MP power brakes. They make a valve for 4 wheel disc that will bolt into the stock location. Check out MPbrakes.com
dr78442 said:VL3359A is the part # and the price is 109 dollars. I used the same valve on my Olds it mounted in the factory location . MP brakes make a really nice product I use them on all my projects. Good luck
