Quarter window felt length.
Killerdave8813
904
Cincinnati,Ohio
That's the main problem,I didn't notice it untill it wouldn't line up correctly with my B piller trim and then started looking a little closer,have you looked at or for the outside window wiper with the chrome bead on it yet? I don't have anything that even resembles that part,do you?
Wile E
1,075
Central WISC
My outer door felts (repo's from Dixie), seem to match the qtr window felts. The bead is a bit larger in diameter then the qtr window bead, but the length was fine and the original mounting holes lined up (doors). I guess my only complaint would be the qtr window felt length is a bit too-long (better than too-short) and the bead placement (that you pointed out KillerDave) could be better to match the door. Otherwise, after dealing with sub-standard parts like "Metro" weatherstrip door seals, I'm happy with the overall qaulity of these felts, not perfect but considering they are not OEM they seem acceptable.
Killerdave8813
904
Cincinnati,Ohio
Cool,I'll have to give Dixie a call when I get back to that phase!!
