race only brakes
rich
1,226
kenniwick wa.
going with a ford 9 all strange comp. looking at brakes frt and rear frt will be art morrison struts whats the best brakes to use i have a wilwood master the man conversion setup from travis like the idea of useing strange to match the rest of the rear end comp. any ideas pluses and or minus also best place to purchase them
Doug Keen
2,259
Central, Illinois
I have Strange on the rear of my Regal and they fit and work flawlessly. The most reasonable place I found them was Hanrahan performance, they adv. on racingjunk.com , I know that Todd G. had an issue with a leaky bleeder or 2 and had a poor cust svc experience with Strange, maybe he'll chime in on this. Overall, I think that for the money Strange's one piece rotor design combined with their low weight makes them a clear leader in the mid range kits. The Wilwood stuff is ok, but I am not a big fan of 2 piece rotors being held together with bolts....
10secBu
4,284
Westminster, MD
I too like the 1 piece rotors. Very nice quality, work as expected...stops very well.
Just not pleased with how Stranges customer support handled my warranty issue.
rich
1,226
kenniwick wa.
LOOKS LIKE I NEED WILWOOD CUZ THE FRT END IS ART MORRISON STRUTS AND THEY ONLY USE WILWOOD i could use strange rear brakes but not sure which master cyl
anyone know what the pedal ratio is on a g body? art morrison says need about 7 to 1 to keep the pressure correct with a 1 1/8 bore
not sure on any of this anyone researched it?
ILLEGAL REGAL
7,160
Tinley Park,IL
on the wilwoods the bolts are drilled for safety wire.. that wouldn't put a scare in me at all... if they're wired correct.
if ya click the link up top in the sponsors Travis sell the wilwood master kit for the g-body which moves the rod higher on the pedal and gives it the correct ratio needed for a disc/disc setup.
rich
1,226
kenniwick wa.
ok not a math wizz here if the top hole which is the pivot point is 2 .25 from the master cly connection point and the center of the pedal is 14.5 inches from the pivot point what the heck is the ratio to old to tired
rich
1,226
kenniwick wa.
MASTER CYLINDER PRESSURE
BORE SIZE ¾ 7/8” 1” 1 1/8
PEDAL RATIO
3:1 1023 750 570 455
4:1 * 1364 1000 759 606
5:1 1705 1250 949 758
6:1 2045 1500 1139 909
7:1 2386 1750 1329 1061
8:1 2727 2000 1519 1212
* G BODY STOCK PEDAL RATIO (from travis
Did a lil research today still looking into this strange and wilwood said you want enough volume at a higher pressure to give a firm but not hard brake pedal
the above chart i found in art morrisons catolog talked to dave at art morrison he said with a 1 1/8 bore i'd want at least a 6.5 to 1 ratio or more to have a good pedal feel for all out race disc all around setup they use a 1" bore with a 6 or 7 to 1 pedal ratio
so i may be selling my 1 1/8" bore new master cylinder not sure yet
rich
1,226
kenniwick wa.
travis said the stock pedal ratio is four to 1 his kit is a 1 1/16 wilwood #260-4893 puts the pressure a lil low about 682 if my math is right not saying this chart is 100% just going by what info i've found so far
