rear disc?
basketcase
9,600
Stockton, CA
www.jackstandracing.com
Since you have 18's on the back...I'd swap over the 4th-Gen F-body brakes. 12", parts readily available from a parts house...and if you shop you can pick up the back pair for under $400. They're a direct bolt on. Just need a fitting to convert the line on the back to the metric crap on the malibu.
basketcase
9,600
Stockton, CA
ILLEGAL REGAL™ said:
thanks Barry,
whats the minimum size rim to use with them? Whats the best for the front.. b-body swap.. but must you use tubular a-arms?
16's or grind the crap out of the caliper to fit a 15".
The fronts you can do the b-body swap. You can do the ZQ8 swap, or if you're a balla, do the C5 swap :D
And for the budget 12" b-body swap http://gparts.freeyellow.com/12brakekit.html
basketcase
9,600
Stockton, CA
zq8= s-10??
Yes...front hubs from 98+ Blazer ZQ8. I've heard good and bad about it. I personally like the idea.
I think at some point ShanaJustin had actually worked out a larger 3rd gen Camaro brake swap using parts from O'reilys but it's been so long I don't remember exactly what all was involved in that particular swap.
