Need the help from you guys. The issue is with my street driven car, which has front disc and rear drum brakes. Everything worked perfect when taken off the road. Car was in storage for 4 years and now I am trying to get her back on the road. Bled and cleaned front calipers, working OK.
Rear brakes are not getting any fluid: pulled bleeder nipples and pumped pedal, zero fluid.
Went to proportioning block and front line port leaks fluid when opened, rear line port is dry.
All parts were new & installed in 2000.
What are the simple steps to find where the issue is. Proportioning block 1st, then check the booster which is a disc/drum 9in unit.
Wish I could just go to the store and purchase a new prop. block but nobody around here ( Rural) stocks this stuff so I need to diagnose what my problem is first. thanks Larry
