K-Star automotive said:What i did was researched for myself what happens with torque vs stretch...
I used 6 or 8 rods of different styles, with different size bolts, And some of the rods had used bolts, some new...All the results were the same,,, The recomended torque never produced the correct stretch....
I found that with the larger bolts you can pull them up to the correct torque and only have .003" / .0035" stretch.... I can always tell when i get an engine in my shop to rebuild that came from a shop that only torqued the bolts,because when i remove the rod nuts there is only .003" / .004" max stretch...
As one example, when i was doing this testing i had a rod with 11/32 arp bolts in it. I pulled it up to the proper torque and checked the stretch it was about .0025" I then took the rod apart and re-machined the cap surface where the nut seated and then re-tested, this time it stretched .0045".. I changed nothing but the finish on the cap.... So as you can see many factors can change the amout a bolt stretches when you only torque them..
As a side note when i was doing this testing I also tried different lubes on the bolts including loctite.... I know the guys at ARP will call me stupid but I am telling you I did not see any difference between the loctite and there super duper moly lube, comparing stretch to torque yeild......Loctite is an excellent lube when it's wet..... I don't use loctite on my rod bolts, but it was a old timers trick around here.... I would think because they did not know about stretch back then...
Try this test.... take a eagle rod with a 7/16 L-19 bolt. lube everything up real good with the proper lube, torque to the stated value and then check the stretch.... It isn't even close to the .0065" recomended ( depending on bolt length).........
Keith
540Malibu said:i use torque figures, once the bolts tight its tight, making it stretch doesnt make anything any tighter, it only brings the bolt closer to its yeild point as the crank tries to sling the cap off. as long as the fastener is capable of handling the stress and rod caps are tight and the bolts not gonna unscrew itself your all set.
any engine builder worth his salt uses stretch figures,Supe said:Stretch.
Well said GeorgeSS402 said:any engine builder worth his salt uses stretch figures,Supe said:Stretch.
torque readings can be misleading and that is one of
several areas that need to be correctly assembled..
George
