S-10 16" rims
timeisrelative
51
OK So I just bought a set of 16" american racing rims off of a guy that used to be on an s-10. I have to get at least 2 new tire due to the fact that the front tires hit my front lower spoiler. Yes they are still truck tires 225/75/16 and 265/70/16, but the 265 looks pretty cool in the rear, a little tight since my body is shifted a little on my frame rails. The fronts will fit in the rear, but look way tall and skinny. Anybody runnin 16 not lowered and have a combo they used? [-o<
timeisrelative
51
OK so I took her out for a spin and the wider tires rub bad. Oh well I only gave 50 for them so no big loss if I have to reskin them
timeisrelative
51
:mrgreen: OK so I found out that they are the "Atlas" line and it looks like they were the polished alloy, but need re buffed, but I think I like them grey. Anybody running a 225/60(or so)/16 on the front? :-s
jrm81bu
413
Antwerp, Ohio
I used to run a 215/60/16 on the front with a 4.5(maybe 4in) backspace rim. It had v6 springs with a small block in it. No problems at all.
jrm81bu
413
Antwerp, Ohio
Now I have 235/50/17 on 17x8's with 4.5 backspace all the way around.
jrm81bu
413
Antwerp, Ohio
timeisrelative said:
:-k Any rubbing issues in the front with the 17's at full lock?
Yep, but I think it is only because the front is so low. This should give you an idea of how low it is. V6 springs that I cut 1 1/2 or so coils out of. By the way the springs were not cut when I was running the 16's either.
timeisrelative
51
Doober said:
Looks like they're silver painted from the picture.
They kinda look like it, but when you get up on them it really just looks like they are oxidized and need a good buffin. :mrgreen:
