SBC Motor Mounts ?????'S
dickeymoore
818
Atlanta,Ga.
I have a SBC 400 that I will be installing in my 1978 Monte Carlo that has a SBC 305 engine in it now and would like to know are there any aftermarket motor mounts that will replace the stock clamshell type motor mounts that will work with the STOCK frame mounts, if so any name and part number?THANKS
ralphl
190
panama city, fl
I have used these several times with great results.
http://www.jegs.com/i/Moroso/710/62630/10002/-1
http://www.jegs.com/i/Moroso/710/62515/10002/-1
These work great if you're not into solid mounts:
They replace the rubber in the stock clamshells & are available in black.
http://www.summitracing.com/parts/ENS-3-1116G/
dickeymoore
818
Atlanta,Ga.
So will the Moroso part# 62515 work with the stock frame mounts or do they have to be used with the aftermarket solid frame mounts,I'm asking about the mounts that bolts to the engine?THANKS
ralphl
190
panama city, fl
As far as I know you would have to use the moroso frame mount the engine mount.
