short bolck for boost! need help
v8power
511
okc
well i decided to turn the regal into a all out race car. i want to run the oklahoma true ten five series, and i need a little more than the small block i have. i want to put a engine together to run a procharger. probally a small block again since i have allot of parts already for them. I do not know where to begin as far as what bottom end componets i should run. i plan and running 20+ psi. are the forged eagle rotating assemblys going to be able to hold that or do i spend the extra money and run a calies crank and compstar rods. same goes with pistions. im just looking for some advice in what driection i should go here. thanks
Excelerater
6,798
Memphis,TN
1) Rod Bolt Upgrade
2) Have machine shop check all clearances and trueness of crank/rods and its journals
3) Have fun.........
Like all mass produced parts some times critical areas need to be
made perfect -
v8power
511
okc
I plan on starting from scratch. Do you guys build short blocks?
