spaghetti menders
siege
179
Hello just have a quick question is there any one on here running a spaghetti menders wiring system if so how do you like it so far and how was the install?
Thank you in advance
Excelerater
6,798
Memphis,TN
I have used it
over priced IMO...its a time saver and pretty reliable for what it does
You can build your own system for half if you have patience and know how
Many racers shy away from wiring a car his system kinda simplifies it
siege
179
thanks for the reply i think i will go with the painless drag kit its a lot cheaper and looks about the same.
10secBu
4,284
Westminster, MD
K&R and Biondo offer wire kits which are similar priced at around $500. These systems use a switch panel which is connected to a main relay board via a computer style serial cable. The main board can mount under the dash which makes for a neat installation.
I don't like regular switches on the roll cage as it's sloppy having all those wires running up and back the cage.
The spaghetti menders system is OK, but if spending that kind of money, I'd much rather have the system from Speedwire.
http://www.gallo-teck.ca/speedwire/
Excelerater
6,798
Memphis,TN
The thing I dont care for on Speedwire is they have all the wires come to one
control center where as SM has a relay board for trunk,engine and pass compartments
which is not only easier to wire up it puts the relays closer to the sources...I am sure
both brands work ok I just like that feature on SM
10secBu
4,284
Westminster, MD
That's the reason I don't like the S/M system. You can't shorten the computer cables when running connections from the main unit to the auxillary modules and your forced to coil up any excess...looks sloppy.
Excelerater
6,798
Memphis,TN
he really needs to do away with the stupid computer cables but you do want the relays close to what your powering
Supe
15,116
Charlotte, NC
I also like the fact that Speedwire has every circuit fused/relayed, unless it needs it or not. When the time comes, the Speedwire setup will be going in the Cutlass.
smedley511
82
glenside pa
i have the spaghetti menders kit. installing it now , when i get it done i will post pics. it seems very nice nice but what do i know, it was expensive, but i here it is the best.
ILLEGAL REGAL
7,160
Tinley Park,IL
Any pics of it installed yet and first hand info of installation?
I really liked how the speedwire is all in one location but also like what Mitch mentioned on the location of relays with SM's. I'm starting to lean towards SM.
