speedway motors tubular control arms
Cam
1,053
Los Osos, CA
Cool, that's good to know!
Maybe my big brake swap is coming up sooner than later ;)
dwkohout
529
Albany,MN
Cam said:
dwkohout said:
UCA's for tall spindle swaps. About $100 for a set. UBMachine PN#14-0809-5R & 14-0809-5L http://www.oldspower.com/vb/showthread.php?t=19243
I have tall spindles on my car and I was really cheap. I shortened the stock arms. :-"
What was the shortened length? I'm thinking it needs to be 6.75-7" or so.
Sorry I don't recall the length.
Cam
1,053
Los Osos, CA
thrashin said:
The UB Machine arms are listed at 8 inches long. I am pretty sure that the stock a's are 8 or 8.5 inches. Are you using alot of shims?
That special part number, found on their "special applications" page is shorter I believe. The stock arms are 8 inches, you need around 7" for the tall spindle conversion.
Horsepwraddict
1,581
Princeton MA
I just put a set on my S10, i used two right side arms and they went on just fine. I called speedway and they said to torque the cross shaft bolts to 55 ft/lbs for the aluminum cross shaft arms in case anyone was wondering.
Horsepwraddict
1,581
Princeton MA
They give you quite a bit of negative camber also I noticed, along with putting the balljoint at a pretty extreme angle. I have a pretty tall vehicle though, a lowered vehicle wouldn't have such an exagerated condition with the ball joint.
Cam
1,053
Los Osos, CA
Yeah they do not have the same drop built into them that some of the other after-market ones have. As long as you don't hit the limits of the balljoint at full droop it should be OK, if not ideal.
They really give you a lot of negative camber? Maybe that's related to your ride height as well... they are supposedly the same length as the stock arms, maybe .5" shorter, but most G-bodies need around .5" of camber shims for spec. alignment anyways, so it works out OK. I don't know about an S10.
So these are okay for the street even with bumpy roads etc. I really like the look and the price!
Trickbu
