I am in the process of putting an 8.8 in my 79 Malibu.
I have adjustable lowers and uppers, my question is how do you all square up the rear with the lower bars.
I'll tell the way I did it and tell me what you think.
I first tried to get equal distance by picking 2 different holes in the frame about 18" in front of the axle.
I turned the lower bars until both sides was equal. Now I checked from 2 different frame holes on both sides and I got it to where it was equal.
But then I was reading on line about using the front lower A-arm grease zerts to measure an X pattern from the LF grease zert to the RR lower control arm bolt on the rearend. Now when I do this LF to RR is 118 1/4" and the RF to LR is 118".
So does this mean the rear is 1/4" out of square?
Just trying to figure out the best way to set this WITHOUT going to a 4 wheel alignment shop.
Thanks
Tony
Thanks
Tony
