T56 Swap
83LSWagon
592
Spring Hill, FL
So I plan on jumping in to this over the summer and using the vette trans I have here. Tryin to get a parts list up
1) Tailshaft housing
2) Output shaft
3) Bellhousing
4) Throw out bearing
5) Slave cylinder.
Thats what I know I need, but I want to run a hydraulic setup. Is there a different pedal I have to buy, or will the ones for the G-Bodies work?
6spdmalibu
112
Vancouver BC
Did a small write up on the hydraulic setup. The car is still in the mock up stage so don't mind the rust. Hope this helps.
http://www.maliburacing.com/forum/viewtopic.php?f=7&t=94053
83LSWagon
592
Spring Hill, FL
=D> \:D/
THANKS!!
I have an olllld thread that covers a few other things as well, may be of some help.
http://maliburacing.com/forum/viewtopic.php?f=7&t=59266
BigG
Member
May 3, 2010
8
I Put a t-56 in my 85 Camino using all Trans am parts. There are pics on the website BigGautoservice.com under projects
malibu795
1,496
4
spgfd ohio
i bought a D&D performance t56 lake wood bellhousing viper spec30 spline output
mcloed hyd slip on t/o
4th gen hyd clutch system then had a -4 fitting put on then end so i could bolt it easiliy to then mcloed t/o
had dennys drive shaft make me a unit 1350 seris is the oly yoke that comes out of it...
john bedzel clutch pedel
one of g-force first t56 xmembers
alos recently swapped out the VSS to form a 3 wire dodge unit to a 2 wire ford which D&D mailed to me at no cost. then whole they use is 15/16
83LSWagon
592
Spring Hill, FL
Is john B still selling pedals?
