taller upper ball joint?
melloelky
3,654
31
mass
I've been toying with the idea of upgrading my uppers and was wondering if i should go with the taller ubj's as well?thoughts?
malibu795
1,496
4
spgfd ohio
it helps road handling geometry greatly if its already apart and your doing them... do then get it aligned again
melloelky
3,654
31
mass
thanks, i haven't had it aligned yet so i thought now would be the time to ask this since i have no experience with them.
malibu795
1,496
4
spgfd ohio
it increase + camber gain on compression.
It increases negative camber, but not by much. If you're replacing them anyway, there's no reason not to use the tall ones. Every little bit helps.
melloelky
3,654
31
mass
good enough for me.thanks guys
melloelky
3,654
31
mass
i don't have one to offer,I've been shopping around and noticed it's an option available on some control arms.I've seen them by Howe on sc&c and umi also sells the taller joints.I've seen them by Proforged on summit's site as well.
UMI Sales
254
Sorry for the late reply. The tall upper ball joint allows for a "normal" tire friendly static alignment while improving negative camber gain during bump travel. The 1/2" taller ball joint is a pretty good improvement in performance vs cost. It doesn't turn your car into an F1 car but does help nicely during cornering.
We load them in our upper arms as an upgrade and also sell them individually if you plan to use your own arms.
We've found that the 1/2" taller upper ball joints work in factory arms without much issue. Our test car has tall upper and lower ball joints which gives a full inch of spindle height which is too much misalignment for factory arms.
Let me know if you have any questions. Happy to help.
melloelky
3,654
31
mass
thanks Ramey,yourself and Ryan have been a big help.
