That's not correct. Bump steer will be the same or worse but no better with taller lower ball joints, because the spindle does NOT actually move. The lower A arm does, but not where it would improve a G body's bump steer. It moves the outside end by the ball joint toward the ground and it will also decrease your ride height. To improve the stock bump steer you need to lower the outer tie rod end to make it have the closer to the same angle as the lower A arm. By using a taller lower ball joint the lower A arm will now be at an even worse angle to the tie rod than it was stock.
I think Marcus was probably telling you to use taller UPPER ball joints. That increases the camber curve, but still does nothing for the bump steer.
What are you planning that the bump steer is of such a huge concern? A $175.00 Baer Tracker kit will improve the stock bump steer all by itself.
