TH-400 case
pldmalibumalibu
288
The 508
I was told that the 6 bolt case I have will not be good for a perfomance rebuild . Do I need to go find a 8 bolt case now ? The trans I have now has HD 46 cast into the bellhousing and the front pump has the 895 on it.
1981Regal
1,274
Cincinnati, Ohio
They might be referring to the 4L80E but the th400 should be fine. Far as I recall all the th400s have a 6 bolt tailshaft housing.
We have not found any significant power limitations (within reason) to the 6-bolt TH400 transmission case. We have a customer with a 3,000 pound drag radial car equipped with an alcohol EFI 632 and an F-3R 136 ProCharger utilizing a 6-bolt TH400 case without any issues. Another customer of ours runs a 6-bolt case behind his 498 DRCE II combination that turns upwards of 10,200 RPM, and, again, has had no issues.
We do prefer to use an 8-bolt case when we're building a unit for use with a JW Ultrabell simply because having the extra two bolts in there provides an even stronger joint between the bellhousing and case, but we've used JW bellhousings on 6-bolt cases without any problems as well.
pldmalibumalibu
288
The 508
Thanks for the info. I have a 78 Malibu that weighs 3600 lbs with the driver .Its got a F1a ProCharged 468 Big-Block . Stepping up to a TH-400 & a 9''rearend so I can turn up the boost. I was curious about the case because I had never heard of people shying away from the 6 bolt cases. The car goes 10.02 now with a TH350 & a 8.5 GN rearend but the trans let go at the end of the season so Im doing it all at once so im not cutting the driveshaft more than once. I run Radial -Pros & will be using a trans-brake.
No issues at all with a 6-bolt case in that combination. You have nothing to fear. Whoever is telling you to avoid that case is providing incorrect information.
B drivetrain help turbo 400 Transmission Technical 2
D Small block Chevy 400 engine with different pistons in it ?? Drivetrain Technical 2
D SBC 400 COMPRESSION RATIO? ?'S Drivetrain Technical 1
D What cam for stock SBC 400 engine????'s Drivetrain Technical 9
thumper 2004r or 400 Transmission Technical 4
D Best Intake and Carb for SBC 400 engine???'s Drivetrain Technical 11
G-boz TH-400 "Ears" Transmission Technical 14
CFH87 400 sbc build Drivetrain Technical 7
lilbowtie T-400 locks up in third Drivetrain Technical 4
H th 400 crossmember Transmission Technical 12
D SBC 400 HEADGASKETS???'S Drivetrain Technical 1
D SBC 400 headgaskets ???'s Drivetrain Technical 1
S T 400 mount proob Transmission Technical 3
G 400 trans rebuild Transmission Technical 3
D SBC 400 block value???'s Drivetrain Technical 2
D SBC 400 LEAKING REAR MAIN SEAL ???'S Drivetrain Technical 8
D SBC 400 .60 OVER ???"S Drivetrain Technical 1
D SBC 400 .60 OVER ???"S Drivetrain Technical 13
D Oil Leak on SBC 400 engine???'s Drivetrain Technical 6
M 400 turbo dipstick Transmission Technical 3
footbrake Burnout with a 400 Transmission Technical 17
R 400 trans in 79 El Camino Drivetrain Technical 20
8 350 or 400 Drivetrain Technical 11
Brian79 sbc 400 casting, which is best? Drivetrain Technical 13
N whats the max i can do with a 400 block? Drivetrain Technical 5
P factory 400 block Drivetrain Technical 27
A ? +60 400 sbc Drivetrain Technical 10
jitteryguy SB 400 Drivetrain Technical 3
A th 400 problems Drivetrain Technical 6
A BIG BLOCK/TURBO 400 TRANS Transmission Technical 3
Deuce4935 Th-400/Lt1 Transmission Technical 1
L turbo 400 or 2004r to lq4 LSx Tech 3
B 400 small block wich way to go Drivetrain Technical 6
D 4L60/4L60E case fittings... are they the same? Transmission Technical 2
D GM techs (or anyone else that may know) - 4wd t-case ? Transmission Technical 15
wiseman79 In case anybodies looking... LSx Tech 0
