The volt meter dropped to the orange line?
78elk
1,294
81
Mountain Home Id
I started up the 78 Elk again today. The volt meter dropped to the orange line. Is there any part I need to check in the alternator or do I need to replace the alternator?
melloelky
3,654
mass
try testing the voltage coming out of the alternator,then @the battery.
78elk
1,294
81
Mountain Home Id
Thank you for your help. How do I do that? I have a meter but don't know where to connect the meter. The battery isn't very old and works great.
melloelky
3,654
mass
with the car running place the + lead of the meter on the stud that comes out of the back and ground the - lead.
78elk
1,294
81
Mountain Home Id
There's 3 wires connected to the alternator. Two are together and one by itself. Which one is the one I need to check?
melloelky
3,654
mass
the one by itself should be a larger single red wire,that one.not the two smaller ones that are contained in a plastic plug.
melloelky
3,654
mass
So the single one is the one I need to check? If it's working properly, I should read 13 volts?
yes,it will be a large/single wire with a ring termineral crimped onto it and it should be attached to a stud via a small nut.anywhere from 13 volts or higher indicates a charging alternator.
