Trans Speedometer Cable Seal TH350
gbodyera
190
Miami- Detroit
Does anyone know where I can get the gasket/ o-ring from that goes where the speedo cable screws in? On a 350 trans.
Phoneguy
284
Central fl
You can get the whole "bullet" fir around $10 if I rember right from summit. It's tci brand and has all the seals installed
gbodyera
190
Miami- Detroit
Ok. I found it. Is this what I have to take off of the end of the cable?
Phoneguy
284
Central fl
Your cable will unscrew from it then there is a small bolt holding a tab on the tailshaft. Loosen the bolt and the tab should swing clear or take it off completely. The "bullet" will pull out with the driven gear in it. Just slide out the gear and put it in to the new one and reverse the process.
gbodyera
190
Miami- Detroit
Cool. I havent done this since last summer, so IIRC, will I have to drain all trans fluid 1st to prevent leaking from the hole?
Phoneguy
284
Central fl
No you don't need to drain the fluid. There shouldn't be any up that high. What oil does get back there is splashed there.
gbodyera
190
Miami- Detroit
Well i got the trans gear housing and it worked. No leaks anymore. Thanks phoneguy
Phoneguy
284
Central fl
No problem. You could maybe have found just the seal and o ring but it's alot easier to change the whole thing
