I had a crossmember fabricated out of 2" square steel with 3/8" steel to make the exhausts cut-outs. With the weight of the transmission on it I find that there is some flex when I pull down and push up on the transmission. Should the crossmember be completely rigid or is some flex acceptable.? I was thinking of adding gussets to the cut-outs to try to stiffen it if necessary.
