Transmission
HOTRODTWAN81
New Member
Sep 3, 2011
4
Looking for a few recommendation on 700r transmission I here good and bad things about them holding horsepower. I have a 355 SBC , that's put out 400hp+. My rear end has 3.73s , iam looking to hit my local drag strip and drive on the freeway to carshow. Any info would be "gladly appreciated"
bbc-olds
538
Malin OR
Would be ok with the right parts installed. 4L80E would be a better choice.
melloelky
3,592
mass
swapping in a 200r4 would be more of a bolt in swap over any other OD trans out there.
80 MICH BU
1,012
Mid Michigan
I have similar set up. As far the drag strip goes, the trans shifts to second on its own at 5000. Also 2-3 same thing, you won’t need 4th. Great for cruising though.
Sent from my iPhone using Tapatalk
