two stage system
foureyed
124
janesville,wi 53548
I am wanting to put a two stage system on my car. My question is how to take the proper amount of timing out for the second stage. I have a digital 6 so the first stage will be retarded off that. And also id like anyones opinion on the 2 stage for sale here. Its not a cross bar its a parallel bar. I've heard the bottom bar might freeze up when the top is activated.thanks for any guidance. Big Papa.
foureyed
124
janesville,wi 53548
Bump.
foureyed
124
janesville,wi 53548
Thanks for all the replies guys. I will answer my own question. MSD makes a box that is a multiple system timing retard.pretty cool
http://www.msdignition.com/Products/RPM/Timing_Controls/Timing_Controls/8975_-_Digital_Multi-Retard.aspx
junk racing
I have a nx dual stage plate, i only have it pilled for 100 and 100. on the first stage i have 0 timing pulled second stage i have 4 degrees pulled also running a digital 6 box and a dedicated nos fuel system with 110...runs 6.40s this way
so its 200 total 4 degrees retarded on the spray....
foureyed
124
janesville,wi 53548
wow not much retard. i was running a 150 single shot. was taking out 6 degrees. i was always told 2 degrees for every 50 hp shot
art
249
Mastic, New York 11950
I ran a 100 shot on a plate and took no timing out either. Plugs told me I could add timing, but did not because of my cast pistons. I was getting ready to add some more when my car got stolen, so I cannot really help any further.
foureyed
124
janesville,wi 53548
Up in wisconsin we use this gadget called a wide band o2 sensor hooked to a laptop so we get accurate and immediate readings.
junk racing
