Well, after I read quite a bit into it, I realized the possibility of huge power while at the same time getting over 60 mpg. I know most people aren't doing this but I have to ask, how many have actually tried to? How far did you take the concept?
What Summit racing offers is no different than a PCV scrubber system which I use already and they can be made for around $20 from Home Depot parts. So here's a basic idea and I will add data to support this every step of the way...keep in mind I have read a lot on this and have got an engine design on paper ready to go. The whole idea is to use electrolysis to split the H20 into HHO or Browns Gas. I know what you're thinking already and no this is NOT a cheesy $100 "run your car on water" system here. There are big benefits to using Hydrogen gas mixed with regular pump gas. Molecule for molecule, Hydrogen is 6X more combustable than gasoline when ignited. Also, it has an extremely broad range of flammability which means it can handle very high cylinder pressures...ie high comp. motors on say...pump gas? Also, the oxygen present as a vapor mist expands rapidly and acts as a cooling agent inside the cylinder, reducing exghaust temps and lowering overall engine temps. But now you might ask isn't it bad to run an engine too cool? You have to burn off all those hydrocarbons... Well, you don't have to. Oil companies have long known about a process called carbon cracking-this is the process by which long carbon chains are broken down into the simplest molecules so that they can burn quickly and completely. Sound familiar? You guys who run high octane fuels know how clean it keeps the inside of your motor, right? No carbon deposits, right? Well, the high octane fuel have chemicals that aid in breaking the fuel down because higher compression motors require it. When you hear about water fuel kits offereing a "covalizer", what they are offering is a highly concentrated mix of agents that aid in breaking doen your nasty pump gas so it burns more completely inside the motor leaving nearly zero unburnt hydrocarbons and producing no sig. emissions. Now, we all know detonation results from unburnt hydrocarbons left in the combustion chamber, right? If running a water system that utilizes hydrogen gas combined with a covalizer in the gas tank can yield big combustion potential without the risk of detonating, you should be able to build a 13:1 motor on pump gas with no issues. Now, since hydrogen vapors are 6x more powerful than gasoline ones when it is ignited, that means you can lean out the fuel to the point where you can approach 100 mpg without a problem. This is not science fiction, it's chemistry. It is very odd that the 5 biggest oil companies own the majority of hydrogen technology that has been patented over the last century by ordinary guys for the most part who have sold out. There are a few guys who resisted and continue to resist the $$$ temptation. Do a search on Stanley Meyers just to name one. He built a dune buggy in the late 70's that ran over 60 mph on just water! I know rigth now the US military has a HumVee that runs on water power alone....the guy who told me about it said this thing did an all wheel drive burn-out and had insane acceleration. There is a lot more going on than people realize and soon I think it's going to come to a head....anybody see the newest ExxonMobil commercials? They are hintign at hydrogen water power as the future.....it's here already but it appears big oil wants to be the one to market it, not the little guys. On paper, I am fully confident that I can put together a short stroke-long rod engine (to me this is the optimum rotating assembly to take advantage of the very fast rate of burn) @ 13:1 comp., run it on pump gas and get north of 60 mpg. I call it my 660 project, 600 hp and 60 mpg. Thoughts?
