wats the best control arm set up for traction
Bigbrute
23
cincinnati ohio
any one using lake food lift bars also thinking bout moros trick springs but i drive the car offten (collage student lol) also wat would be the best bolt in uca an lca i know not trz just trying to save money
also wanna c wat other peoples opions are wats the best rear end set up
CutlassRacer
5,402
Gainesville, FL
www.facebook.com
Aside from cutting down on wheel hop from the use of better bushings, no control arm is going to give you traction by itself. The amount of traction in these cars is more determined by the angle of the control arms in relation to each other, the amount of power available, the type of shock used, etc etc.
When I buy parts I try and research who makes the best/most proven and then that is what I will buy. TRZ still has the records for the quickest 60ft on a stock suspension G-body so that should tell you a little bit ;)
Bigbrute
23
cincinnati ohio
ok thanks i been looking at the trz parts just on a budget im using et slicks an a 410
