What converter?
k9
1,122
CHICAGO
What size converter would probably be optimum behind a 468 w/ a .748/.710 274/284 110 in a 3200 lb bu with a 4:56 gear 28X10.50 tire 1/4 mile only
Goob
3,641
Indianapolis
Naturally aspirated?
Compression?
I'll assume by the cam spec that it has some good compression?
5200-5500 stall, probably an 8", unless you're gonna gas it.
Might want less rear gear.
the specs look alot like my old cam,crane r274 :-k if so it likes a 5500,that set up ran 10.3 for me w/more tire 29/12.50/15 on a 15x10 superlite and frame notch
k9
1,122
CHICAGO
CR 13.5:1 naturally aspirated but I will be trying some juice later I have been wondering how it would perform with a 4:10 gear
Compression?
454RAT
2,012
Summerville, SC
that motor N/A will like a 8 inch converter between 5700-6100. with some spray you will have to go to a 9-10 inch and probably around a 4700 stall.
if you want to spray it some times but still want to run good on motor i would use a ptc 8inth 00. it be little tight on motor but should still go 5300 or so on the brake. if you call talk to Tim or Lane they will get you fixed up with what you need. PTCs number is 256-383-6868
