what heads to use
jessie355
21
Ringgold GA 30736
i have a standered 350 with stock 350 rods pistons with slight dish and four valve reliefs and i have a set of 305 ho heads with centerbolt valve covers set of stock 350 heads and a set of 882 305 heads have 184 150 my heads that came off of the motor that have 194 150 and i believe the 882 have 202 160 witch would be better am lookin for more power i heard the more flow the more power along with the lowr the cc the higher the comp and power ??
I wouldn't use either of the 305 heads on a 350. The valves & ports are too small. Even if you upped the valve sizes, the valves would shroud the ports too much.
cobalt327
56
Atlanta
What are you going to use the vehicle for? What IS the vehicle, for that matter. What rear gears and transmission are you using? What camshaft?
A lot of guys have successfully used 305 heads, but not just ANY 305 head, and they will need some work to get the most from them. Are you able to do your own work, even as far as grinding on a cylinder head? If not, the 305 heads might not be for you, unless you only need a lot of torque to about 5000RPM max.
What is the casting numbers of the 305 heads w/the 1.84" intakes?
882's- even w/2.02 X 1.60" valves- leave quite a bit to be desired. They might be the best option, though- especially if your app means you need to turn more than 5K RPM and still be making some power. Have they had any port work done? Pocket porting- at least- will be needed to blend the larger seats into the bowl smoothly.
