What kills stock diffs ?
shewbu
17
Is it horsepower or combination of hp and traction that will kill the stock rear on a malibu? My 80 Malibu wagon has 300hp 350. Too slow. Was about to order ZZ383 but now wonder, should I do rearend first? It's my daily driver so will not have slicks and repeated drag race passes until I can sort out new rearend. On same topic what is easiest bolt in rear? Not many GNs or 442s being parted out up here in Canada but tons of S10s, which I have reason to believe might be a good donor for a casual racer. t or f ? :-k
The stock rear won't appreciate a ZZ383 very much. Even if you Grandma drive it, it's just a matter of time. I'd say step up the rear first.
cutlass389
684
NC
#1 killer is shock loading, as in a hard launch with weight transfer and the tires glued to the surface or a spinning tire that suddenly finds traction. Other causes are exceeding torque capacities of components and if ya' think about it, how many years if not decades has it been in service probably without a single fluid change.
jazzbo
448
Lebanon, Tn
If you arent there hooking up on a track and not abusing the thing, it will be allright till you get the money to upgrade the rear.
S10 rears are not as wide as a malibu so you couldnt use the whole thing but you can use whats in them. The gears, posi's, etc.
Just take it easy on it till then.
shewbu
17
Just checking thru reciepts from previos car owner. has new auburn posi AG542058-HP + new gears. Is this any better than stock?
hopeful
kevind
868
Whitley City KY
Anything has to be better than stock. A couple of good hard 4 speed shifts and the rear ends shot.
DOUG213XRJ
4,671
West, MI
For a street car, Im going with lack of mainence and betting the snot out of them.
