whats better a tight or loose stall?
bowtie81
5,008
sarnia, ontario canada
im just wondering what would be better, i like the sound of a loose stall but not sure if its better than a tight one.
holtjohn
516
what are you wanting the stall for, if I not mistaken you said your car was supercharged. I would have to say that most people would say that you need a tighter stall with a blower cause of the low end torque they make. The blower will cause a loose stall to flash way higher that the advertised number and if it is gonna be drove on the street that will make the transmission get really hot. But if it isnt for that motor than you just need to state what motor it is gonna be behind.
bowtie81
5,008
its going behind mine, i just wanted to know which way would be best for my setup. my stall is a tight one, as long as know i've got the right one for my application im happy.
Thanks
holtjohn
516
Well what is your application? Is it a street car or race car or is it like 50/50 and what size do you have now?
bowtie81
5,008
350 60 over 9.5-1 compression, dart pro1 200 intake runner 72cc chamber, b&m 162 blower, 750 demon 3500 stall, 456 gears but going down to 410. street and strip, the cam is 510-533 lift with 244 254 duration @50 114 lobe seperation.
holtjohn
516
Ya if it was me I would keep it tight to keep the transmission temps down. Just my 2 cents.
Glatt
47
Lethbridge, Alberta, Canada
In my regal I have a fairly tight 3000, for the street the stall speed is great. I know I wasn't making as much power as you but I had a fairly stout 357 that made nearly 400 at the tires. The engine worked very well with the convertor. I have a buddy with a much larger stall convertor (5500 flash ) and its great for the track and sounds rank but his trans gets pretty warm when we cruise. He is actually tightening up the convertor about 1500 rpm this winter.
Arthur
bowtie81
5,008
thank you for the info arthur, almost sounds the same as my buddy and i.
