The M/T 28x11.5x15 ET drags on the rear of the car rubs the notched frame rails when turning. I installed 7/32 wheel spacers and seems to have enough clearance now. My only concern is I leave on the trans brake and I am concerned about breaking wheel studs. I have 1/2" screw in long studs with mcguard open ended lug nuts. The studs are flush with the open end of the nuts. I have made about 50 passes with the tire rubbing the frame rail when I turn only but i need to buy new slicks and trying to decide if I should go with a 10.5 tire with no spacer or stick with the 11.5 that I ran last season and let them rub or use a spacer.
Thanks
Barry
Thanks
Barry
