===================================================79wagonator said:Sorry to hijack but... I have a wheel spacer Q??
I bought those cheapy 1/4 & 5/16 spacers at pep boys and they have unilug (oval) holes when I put them on the front there is no way to center them on the rotor before you bolt the wheel on. I would think Id have a balance issue if its not centered?? What do yous think?? Should I just order the billet ones with right hole pattern or is there a trick or something Im missing?? :?
Dave,
Don't feel bad, buddy. I have the same cheapo ones on front of my wagon. As you bolt up the wheel, just center them. I suppose you could probably use the double stick tape trick to get them centered on to the hub/rotor (or drum).
The new ones I get are for my FWD Olds with larger wheels. Many of them have that uni-lug pattern...unless you get ones specifically for your 5-bolt pattern.
Jack
Jack
