which springs? -now which spacer?????
Apathy93Z
164
Loveland, CO
Hey all, right now I have eibach lowering springs, the front rubs the fender lip and rear will hit the exhaust over speed bumps, so now I'm thinking maybe stock height would be better but with some better springs, been looking all over the place and at charts but would like to hear from people who have some real world experience with the moog springs. I'm running 16x8 s10 zq8 wheels with 245/50 series tires, i actually like the stance it has now but could use a little more lift maybe. Been so long since i've seen it factory height i don't remember what it looked like, the car was raised before I lowered it hehe
thanks in advance
malibu795
1,497
spgfd ohio
Re: which springs?????
this is mine with stock worn out everything. SBC/th350 with 245/60/14
side shot
with BBC/t56 235/60/14 on the 245/60/15 on the back
5608 fornt qa1 14x175 rear poly bushing suspesion
234/60/14 SBC/t56 5608/stock with air shocks pumped up in the back
Apathy93Z
164
Loveland, CO
Ok so I went with moog 5662 in the front and 5413 in the rear, now the front sits too high so I'm going with some drop spindles, but the other problem I have is that the drivers side sits 1/2" lower on the front, I've seen where Phillip used a spacer on the left front which is what I was thinking of using a .500 spacer, but reading the description it says they raise the vehicle 2.5-3.0x higher so which spacer do I use?
