will a stock th350 work on a 5.3?????
G-BUDDY
Member
Jan 20, 2011
8
so i found a good 5-3 and i also have a good stock th350 and was wondering if it will work behind a 5.3
will i need to use a built th350 or will the stock one work for now, also will i need a shift kit, maybe a stall and if so what stall is recomended? i know i need the spacer-adapter for the transmission but will it work ok thanks guys for the help!!!
SSedan64
948
MACON, GA.
If the Trans is in good shape it should hold up fine. A Shift Kit and External Trans Cooler is always a good idea.
Your Cam selection, Rear Gear etc.. will determine what Stall rating the TC needs.
A stock TH350 in good internal condition will provide good performance and reliability with a stock or mildly modified 5.3 engine. A TransGo shift improvement kit is a good investment, as well as a decent size external fluid cooler. The shift improvement kit will provide a firmer, faster shift which will help reduce slippage and improve the life of the friction materials in the transmission. Our GM25 torque converter is a great choice with a stock or mildly modified 5.3. This is a 12" converter with an advertised stall speed rating of 2,500 RPM. Depending on rear axle ratio, rear tire size, and vehicle weight, this converter will typically provide 2,000 - 2,200 RPM of actual stall speed with an engine such as yours. We also offer the TransGo kit under part number 350-2, as well as flexplate part number HP4004X and pilot adapter part number HP3795.
