Wilwood brakes on front what rears?
TurboBu
32
Sw Missouri
putting wilwood prostreet kit on front dynalite 4 piston 1.75 dia w/vented rotors. And I'm kind of up in the air as to what i'm putting on the rear. this is a drag radial/street car w/315's on back and skinnies on the front. If budget permitted I would spring for matching wilwood's on rear but low on $$$. What i've considered so far: Junk yard late 90's explorer brakes, or late grand marque rotors w/g-body calipers and weld on brackets, or wilwood aluminum hats, speedway rotors and g-body calipers. Also converting to manual M/C do I want 1" or 1 1/8" bore w/ single piston rear calipers? anyone have better cheap rear caliper suggestion. By the way car has a 9" w/4.5" pattern.
gman415
883
Chattanooga
Put the Wildwoods on the front and 79/80 Trans am 4wd rotors on the rear with your old front calipers, had a freind make some brackets but we used them all. Can't remember what m\c to use.
TurboBu
32
Sw Missouri
no that's fine the only difference is that I would be using Crown Vic rotors instead of firebird. Are you running any sort of propotioning valve? With which master?
